ORIS
Re: ORIS
πραγματι πολυ ομορφο και λιτο κομματι ... μηχανισμος λεει Selita ...ενδιαφερον :good:
Re: ORIS
From ORIS Breath Taking Oris Carlos Coste Limited Edition Cenote Series - In 2010, Carlos Coste established a new Guinness World Record for freediving, by completing a 150 metre underwater swim using no apparatus through Dos Ojos, a colossal cenote (cave network) that twists for 31 miles under Yucatan, Mexico. The Venezuelan was armed with only a torch and a monofin when he made the death-defying dive and now Oris have honoured this great achievement by creating a special Carlos Coste Limited Edition Cenote Series watch.
ORIS Carlos Coste Limited Edition – Cenote Series No. 674 7655 7184-Set Ø 46.00mm - Limited to 2000 pieces
Automatic mechanical chronograph movement ETA 7750 with red rotor Hour, minute and stop second from the centre, subsidiary dials at 6, 9 and 12 h position.
Titanium case with ceramic top ring and Superluminova inlay and screwed case back with Carlos Coste’s logo
- Pushers and screw down crown in stainless steel
- Automatic helium valve at 9 o’clock position
- Water resistant to 50 bar / 500 metres
- Black dial with applied indices filled with Superluminova
- Titanium metal bracelet with easy adjustable folding clasp
SET Multipurpose soft pouch, replacement rubber strap, tools for the bracelet change. Limited edition certificate
http://oceanictime.blogspot.com/2011/04 ... s-new.html
jimko7
Been thanked: 16 times
Re: ORIS
Δημοσίευση από jimko7 »
Πολύ ενδιαφέρον..!! :magn:
ΔΗΜΗΤΡΗΣ
 ΕικόναΕικόναΕικόνα
Re: ORIS
Μιλαμε για πολυ εργαλειο!
Re: ORIS
Φοβερο κομματι και η συσκευασια ολα τα λεφτα! :good:
Marine master
Has thanked: 27 times
Been thanked: 78 times
Re: ORIS
Καλό δε λέω, oris = tank αλλά πάλι μουσακά βρε παιδιά; Μου αρέσει αλλά τον βαρέθηκα συνέχεια....αυτοί κανά νέο ρολόι, καμιά νέα καλίμπρα δε θα μας δείξουν;
jimko7
Re: ORIS
Όταν η 7750 έχει δοκιμαστεί τόσα χρόνια..τι πιο αξιόπιστη λύση να ακολουθήσεις?
Δηλ. η 7750 σε χάλασε? Εδώ πχ. η Breitling ακόμα τη χρησιμοποιεί..μάλλον κάτι θα ξέρουν καλύτερα αυτοί ;)
Και όσο για την ποιότητα ORIS δε νομίζω ότι έχει κανείς να πει κάτι..
ΔΗΜΗΤΡΗΣ
 ΕικόναΕικόναΕικόνα
Re: ORIS
ενδιαφερον κομματι ...αραγε ποια ειναι η τιμη του ?
pontioz
Been thanked: 1232 times
Re: ORIS
Δημοσίευση από pontioz »
Το κούμπωμα σπό το λουρί είναι εντυπωσιακό!
Πισγιουνίκ.
Marine master
Re: ORIS
jimko7 έγραψε:Όταν η 7750 έχει δοκιμαστεί τόσα χρόνια..τι πιο αξιόπιστη λύση να ακολουθήσεις?
Δεν είπα κάτι για την ποιότητα τους, για την 7750 αυτό που με χαλάει είναι οτι έχω ήδη 2 και δεν έχω διάθεση να τις κάνω 10.
