Muhle Glashutte
- Has thanked: 39066 times
- Been thanked: 8474 times
Re: Muhle Glashutte
αυτο το μοντελο μου αρεσει πολυ περισσοτερο απο το προηγουμενο που παρεθεσε ο Μαριος
πραγματι ομως οπως εγραψε ο Θοδωρης ειναι λιγο τσιμπημενες οι τιμες ..890 ευρω για αυτο !!
- historic specialist
- Has thanked: 103 times
- Been thanked: 440 times
Re: Muhle Glashutte
Αυτό το ....κ@λ@χώρι το Glashutte πληρώνεις, Κώστα μου!!...ομως οπως εγραψε ο Θοδωρης ειναι λιγο τσιμπημενες οι τιμες ..890 ευρω για αυτο !!
Εμένα μου αρέσει το καταδυτικό!
- Has thanked: 48 times
- Been thanked: 194 times
Re: Muhle Glashutte
N E W M o d e l – Muhle-Glashutte Teutonia III Handaufzug
he case, in stainless steel, measures 42mm x 11.2mm. It has a domed AR-coated sapphire crystal and sapphire display back. It is water resistant to 100 meters.
This is the first hand-wound movement from Mühle-Glashütte It has the traditional Glashütte three-quarter plate and the firm’s own woodpecker neck regulation. This ensures that the timing of the movement, which is regulated in six positions, is not altered when the watch is subjected to a sharp jolt. It features a center seconds hand, a date display and a power reserve of 42 hours. The movement measures 25.6mm x 3.4mm.
This is the second movement, after the automatic MU9408, developed by the firm and built at its factories. Mühle-Glashütte is keen on becoming a real manufacture.
MSRP starts at 1,590 Euros.
Thanks.
http://forums.timezone.com/index.php?t= ... sg_5920602
Thanks.
Re: Muhle Glashutte
Ομορφο
Μοιαζει με Chronoswiss
Re: Muhle Glashutte
Mühle-Glashütte MARINUS Chronograph SE Fulda Challenge
By TLex Mühle-Glashütte announce the new MARINUS Chronograph SE Fulda Challenge. It features a solid stainless steel case, which has been coated with DLC, fitted with a sapphire crystal and has a water-resistance of 30ATM. A tough and hardy dive watch - that has qualified for the 2012 Fulda Challenge of which Mühle-Glashütte were the official timekeeper. The watch was exposed to extreme elements and temperatures as low as -40⁰C as it made its way across 1,500 kilometers of Canada's Yukon territory . . .
From Mühle-Glashütte The Marinus Chronograph is distinctive and unscathed as it emerges from the water. But the watch is no longer satisfied with tackling just one element. Whether surfing, snowboarding, sailing or snowshoeing: this outdoor timepiece from Mühle-Glashütte also stands up to the challenges of snow and ice. The Marinus Chronograph has qualified for the Fulda Challenge 2012 thanks to its striking character and is now being launched as a special limited edition.
The strengths of the Marinus Chronograph are evident at a glance: its solid stainless steel case with a black highly resistant DLC coating (diamond like carbon) and 44 mm diameter can live up to any challenge. With its domed 2.5 mm thick sapphire crystal and a resistance to test pressures of 30 ATM, the Marinus Chronograph stands up to external influences such as temperature fluctuations, salt water and changes in pressure. These are all valued properties in the extreme conditions of the Fulda Challenge.
This Arctic decathlon takes place every year in the Yukon Territory in Canada. Athletes battle against the cold along the 1,500 km route as well as tackling the challenges of the individual disciplines which include dog sledding, skijoring and a half marathon at -40⁰C. Mühle-Glashütte took part in the extreme event for the first time this year as the official timekeeper. To mark this commitment, a limited edition series of 250 Marinus Chronograph models was released.
The fact that you can tell the time with the Marinus Chronograph in virtually any conditions is all thanks to the Mühle chronograph movement MU 9408. The patented woodpecker neck regulation guarantees accuracy even under the harshest of conditions.
A 48-hour power reserve, stop-seconds mechanism and fast date corrector complete the technical features of this watch.
The non-reflective sapphire crystal offers an unrestricted view of the black watch face at all times; the white numerals and two totalizers stand out clearly from the background. The uncluttered design means that the small seconds display and minutes counter can be viewed at a glance. The one-sided rotating bezel with its red ceramic insert stands out easily against the otherwise black design of the watch. Thanks to the hands, numerals and indices coated with Super-LumiNova, the watch offers optimal legibility even in dark conditions or under water. The light spot at the zero point on the bezel enhances this further.
Equipped with all of these properties, the Marinus Chronograph can stand up to any challenge, regardless of conditions. This timepiece is the optimal partner for extreme athletes and outdoor enthusiasts who live their lives at the limit.
http://oceanictime.blogspot.com/2012/03 ... ph-se.html
